Pomodoro
Hello! Intend to build this small case only to build industrial drone phrases , but also rhythmic/percussive gates...therefore i wonder what would you choose for an envelope generator! I intend to use the Pons from Noise Engineering ...i didnt have the chance to try several modules ( EG's)...any other suggestions to fit both droney and percussive territories? I'll have to stick with this case size, unfortunatelly ! I have to use a line level output...especially for headphones
VONDENFUNKEN
I like RYK Envy Maschine
You could just use Pamelas Pro Workout for envelopes.
Its all in there.
Might add a Axon 2 expander or some polarizer
A set of Bela Gliss pairs also well with Vihkk x (might be not so handy for envelopes)
Greetings
Chris
Pomodoro
Hard to decide if i shoukd leave aside for now an envelooe generator...knowing that Pamela can cover all that! if so, what woukd you replace it with?
VONDENFUNKEN
in this racksize it´s tricky.
I would try something like this:
https://modulargrid.net/e/racks/view/2867251
But better get a bigger rack. It´s to minimal :D
Greetings
Chris
Pomodoro
oh , i like those! ill give it a thought on each one, how it might sound! droney vs rhythm
Thank you!
the-erc
I have a lot of success with Pique (various makers) which is a 4hp clone of Mutable Instruments Peaks. I almost always use it as a dual envelope generator -- the envelopes are very snappy -- but it can also be a 4-step sequencer, LFOs, or various drum synths. It's an excellent module for a small case.
As an EG its main advantage over Pams is you can tweak the envelope shape quickly and easily by hand... this requires some menu diving in Pams. Also ADSR is available, which Pamela's New Workout doesn't have (I don't know about Pams Pro.)
Pomodoro
Indeed , i should consider immediacy and not too much menu dialing with this small case! thank you!
Pomodoro
-- the-erc
The second rack ( @Vondenfunken suggested ) the one with the envy and junction...kinda covers your suggestion with Pique, right?
