What I'm working on is basically a "randomized" sampler to play live. One of my favorite things about the Microfreak is that you can modulate the arpeggiator/sequencer rate and get really off the grid in a tactile way. I want to do this in a sampler and sort of create like an instrumental hip hop version of free jazz. If there is a hardware sampler that does this (or a MIDI controller like the Torso T1), I haven't found it yet, so my plan is to go modular make the setup posted above. I think this a good simple starting point for the concept. In addition to this stuff, I already own a Moog Mavis, Microfreak, Keystep, and SQ-1, as well as a couple more normal samplers that cover me well in terms of regular usage, so I'm pretty much just focusing on this specific function.
I guess I just thought I'd run it by people here to see if there's anything missing here in order to pull off the bare minimum version of this (or any repeated functionality that I don't need). I tested a version of it in VCV Rack and this seems fine, but hardware is obviously different. Any help would be greatly appreciated.
looks like quite a decent start to me...
personally I'd want some more utilities... as they add more patching options... so versatility
& some modulation - envelope generators/function generators & lfos
and I'd probably go for a bigger case (mantis would be my choice - bigger/quieter/cheaper per hp etc) - sooner or later you'll inevitably need it & you're a bit close to the power specs for the uZeus - at least with the regular psu - & with the higher powered option there's no improvement on the -12v rail - remember to leave at least 20% headroom on all rails (& if you add more modules you'll probably want to change the jumper for the -12v to get the extra 100mA out of it...
Thank you for your help, particularly with the envelope/function generator and power/case aspects. These are areas I was hoping to cheap out on, but I think I won't for now, even if it means holding off on a purchase for longer.
I'm sort of tempted to just go with an updated version of this (should be visible if you click the image) and then see what other utilities I need as I go along. I also have a Bluebox mixer, so I'm at least ok for figuring out how to collect my various audio signals from the modular and send them to the rest of the world.
-- Zacksname
It's not really modular but since you mentioned the MicroFreak. It recently received a firmware update that turns it into a sampler & granular engine. With some additional tweaking, I think you can pull off what you intended, like I show in my video:
https://
