Great combo here, Portable to be used anywhere and a lot of variety for such limited HP.
Battery and Case info
Battery is 66W and it lasts for at least 5 hours and probably more. Bonus USB port on the battery can also be used for a keystep or other accessory if needed at the same time.
https://www.amazon.com/TalentCell-Rechargeable-12000mAh-Multi-led-indicator/dp/B00ME3ZH7C?ref_=ast_sto_dp
Case is 48hp 4ms pod
FYI: One more observation about the battery, The only module issues I have ever seen with this setup is with a squid salmple I used to own. The squid turned on and seemed normal but would not take triggers for whatever reason.
curious about what brand you using for your Lithium Battery? I'm searching some to be able to travel w my 62hp Palette :)
same here, very curious to know your battery solution
-- davebrohl
Using this battery I found on amazon, again it is allowable for airline travel as it is 66W (needs to be under 100W). I have traveled by air with it and security did not give it a second look, although they thought my field microphone I was carrying was some sort of taser because of how the Zoom mics look :).
The battery lasts in my little 48hp for at least 5 hours and probably more as I have not done a real test of how long I can go before it dies or start seeing weirdness in the modules.
NoisyFruitsLab
maybe something like that until a certain point ...
https://noisyfruitslab.com/2022/01/08/mobile-power-for-eurorack-synthesizer/
ecolabaudio.de
-- NoisyFruitsLab
Nice
