User left
Hello everyone, can you show a beginner a few patch ideas of this rack?
alt text
Thanks and greetings
Mixer's in the wrong spot...move it to between the Chips and Rings, then use it to mix the two voice oscillators before sending it to the Rings, where you also "stereoize" the mono signal coming from the VCOs. Then run the ODD and EVEN outs (or one or the other...depends on the sound your aiming for) to the Clouds inputs...provided, of course, you already HAVE a Clouds, because they were discontinued a couple of years or so back. If not, Mutable's Beads is their "mk ii" of the Clouds. That's pretty much the "base configuration" that exists with these.
User left
Thanks for your help. I gradually read myself into the mdular synthesis. I tried it according to your information. Could this patch work?
alt text
If your computer is powerful enough (likely it is) then you can try out module and patch ideas on VCV Rack: https://vcvrack.com/
User left
I tried it in VCV Rack but unfortunately the chipz and cellz module is not included
Almost...you don't need to connect the mixer out to the Rings' CV in...that part of the path is purely audio. You can get the Clouds and Rings to respond to CV by multing one of the CVs coming from the Chips, preferably one controlling a VCO so that it AND the other two modules are responding in heterophony.
TumeniKnobs
Heterophony! Never heard this term before, but it’s something that is in a lot of patches I make, including the “mega-patch” I currently have running. Right on!
Roses are red
Clichés are chronic
Chipz, Rings, and Clouds can be heterophonic
Sorry, it's a few months early...
GarfieldModular
