hello
i am wondering if we can use the time warp module as a shuffle generator by sending a trigger in the input and have different value of swing by turning the corresponding rate knob?
thank you
Dual Channel Gated Slew, Envelope, & Envelope Follower
https://wmdevices.com/products/time-warp
	hello
thank you
	hello
i am wondering if we can use the time warp module as a shuffle generator by sending a trigger in the input and have different value of swing by turning the corresponding rate knob?thank you
-- croute
I don't think so, I believe it will output a sort of AR envelope
	hello
-- croute
It would be very cumbersome to do this as time warp is a slew, not a gate delay. There are some great gate delay modules out there that would be a better fit for this. In theory, if you were using long enough gates for the clock signal, not triggers, you could slew the voltage so it doesn't cross the gate threshold (2.3V for Schmitt Trig inputs), but it would not be exact at all, and tough to nail.
