No user found with username benjibenji
No out 3. Two out 4's.
Simple: you have output 4 and output other 4.
Looking forward to this.
By the way, there's another typo, it says QuadrIphonic.
-- Guitarsenal
It's a prototype, mistakes happen :)
This the best quadraphonic signal processor today (Nov 2022). This module will place one voice in the quadraphonic space using various internal patterns that can be sync to an external clock. Automations can be removed to control via CV the location of the signal using either polar (angle-distance) or cartesian coordinates (x-y).
The strength of this module is because it is tightly integrated with an LFO, which guarantees no audio bleed when the audio signal is abruptly moved from one quadraphonic output to another.
Additionally this module has a configurable output to, for instance, output the distance of the signal to the center. This signal can be send to control the reverb on an input signal. The further the signal is from the center, the more reverb is applied to the audio input, increasing the distance illusion on the final quadraphonic output.
This module can also be used to process mono or stereo, making it a kind of dynamic mixer, input 4 different audio signal and using the sum output get the module to create interesting mixes.
This module gives you many of the capabilities of the Buchla 227e, the reference for quadraphonic, but in Eurorack format. A must have module when starting in quadraphonic.
See more quadraphonic modules at https://www.peachymango.org/EuroQuad
