Thanks for the tips !
NP
  I've been looking at the Mantis also, it's true that I had in mind to quickly change to a bigger case after filling this one, you're right that's it may be a better idea to get a two row one now.
people complain about the price of cases... there's nothing to complain about with the Mantis... other than the usual occaissional lemon and trying to put too many high power modules in it - but this is the same with all cases!!!
  I just learned hours ago that the Bialismus is a VCO not an effect centered module - I had heard several times before that it had great effects I just assumed it was mixing not generating - so you're right that it's too much sources for a start. I'll go with the Plaits, probably, even though the Iteritas one looked fun. The Plonk one is just added while messing with my config, it's a module I'll probably buy much later if it stills interests me.
yep -always helps to read the manual...
  I was heavily leaning on an additional mixer already so that's confirmed.
you'll probably want more than 1 eventually...
  As for Maths, I looked into the docs yesterday and it ticked several boxes for me. Just checked the link you shared, I will look heavily into it, seems like great infos on the module and on modular in general.
yes it's pretty much exactly that - a microcosm of modular - learning to patch program a single module then expands to patch programming a whole modular... and may steer you closer to modular synthesis than 'synthesis with modules' if you get what I mean!!! which will lead you to asking every time you see a cool 'new' module - can I patch that (r very close) with what I already have, and if so will it impact the other modules too much?
  Didn't know about the Mutant Brain, looks like a great alternative !
there are many alternatives to almost every module!!! nb mutant brain is now made by erica synths - you may also be able to get the exact same functionality outside the rack - cv.ocd
  Would you recommend trying my luck at a DIY case ? I've been thinking about it, could save me a few bucks.
I have 8 cases of which 2 were bought, 2 are 19" racks and I built 4 from scratch... if you want something aesthetically pleasing and 'perfect' and are good (and quick) at woodworking, then yes, building a case can save a few quid... but chances are that if this is the case it won't as you'll buy better wood and spend more time and money on finishing it than I did (I bought the cheapest wood I could find and spent nothing on finishing)
my experience as someone who hadn't done any woodworking for 30+ years before building my own cases is: I'm not great at woodworking, but don't really care they are functional and do the job - but that is all!!! did I save a lot? I guesstimate that I just about got 9u 104hp for the price of a mantis... not taking into account time and effort... saying that I did find somewhere that was reasonably priced for rails and insert (often these can be expensive) and I built my own psus/bus boards from kits (befaco excalibus) but mostly they only hold low power analogue modules and/or have a lot of passive modules/space in them - 1 or 2 cases need a 2nd power supply - I use an inexpensive one from frequency central for this - again DIYed - if I had to buy power supplies - I would have got a lot closer to there being no difference - at which point buying a case makes more sense - if it's in the price/size range of a mantis... if I'd had to buy any of the tools I'd also not have saved money - I borrowed a drill and cut the wood at the DIY store I bought it from
in other words you're not going to save a great deal, if anything, building a case - so if you're doing it to save money - and could be doing something better with your time - do that instead and buy the case... unless you like diy and have the saw/drill/soldering kit etc already
