No user found with username AcgNrg
Is there a way to lock the current panel images in a rack, so that they aren’t updated whenever someone uploads a new image?
It looks like if I select something other than the default image when adding a module, that image is saved. But if I use the default image, it isn’t saved and gets updated every time a new image is added for the module.
This seems like the opposite of the behavior you’d want most of the time. It doesn’t seem like there’s really ever a situation where someone would setup a rack, but want modules to update when a new revision comes out, or when someone uploads a custom image from their own rack.
https://www.modulargrid.net/e/forum/posts/index/1749
Other people who have set their module image to HEAD version (default) will see your newly uploaded image.
HEAD means: always show the newest image.
If they switch to an older version it will stick there, newly uploaded images will not affect their racks.
Is there a way to set the current module image to something other than HEAD even if someone wants the current default image? (So that a rack isn’t following the HEAD image, and doesn’t update when a new image is uploaded.)
Seems like this would maybe make sense as the default behavior. Rather than setting the module image to HEAD by default, just set it to whatever the current default image is, but stick with that image permanently.
To use an example, if I add a module to a rack with, say, a silver panel as the default and only image, then that’s probably the version of the module I own. If someone uploads a black panel later, I probably don’t want my rack to get updated with the black image. Seems like there’s no way to do that now, unless I re-upload (duplicate) the silver panel image and select the old version when adding the module to a rack, which would be a bit silly.
It’s always a little weird to come back to a rack after a few months and find out a couple of the module images have been switched out to a version I didn’t originally have in the rack and don’t actually own.
-- chaos215bar2
simply choose everything but not HEAD
EDIT
ensure you have enabled the panel selector (top right of the rack)
further i misunderstood your question :D
in my opinion it makes sense to have modules default image set to HEAD because there are often improvements in quality or perspective.
Indeed! I hadn't really used the panel selector much. It is possible to switch from HEAD to 1/N there, pointing directly at the most recent image.
I still think it would make more sense not to default to HEAD. In my experience, updated images are almost always a new panel color or someone uploading a (usually lower quality, and not matching other images from the same manufacturer) image of the actual panel from their rack. If someone uploads a higher quality image, it usually happens within a short time of a module's release, so usually that image is already in the database by the time I'm adding a module to my rack.
