No user found with username Warren
Not long for an ALM 52hp 6U case and tonight after finally getting a few modules decided to set it up. All was working ok until I tried to screw down the top row of modules, they don’t fit! So I relocated them to the bottom row and they’re a perfect fit, back to the top row with 2 x new modules and it’s a no go again. It looks like the top row is 2mm undersize.
Obviously I’ll give the retailer a call in the morning but I just wondered if this is a common problem or if there’s an easy work around?
Sorry you're having problems, Magicaxeman. I had a similar thing whereby the rail in question wasn't quite "square" - it was bolted in at a slight angle. Loosening the screws at either end then rotating it around a bit then tightening the screws again fixed the issue. Hope that makes sense, and good luck :)
Thanks Bleep, just waiting to here from support then I’ll give that a go.
That worked a treat, thanks
