Hello! Can anyone tell me if this synth ecosystem has enough pieces to function and make a wide variety of sounds? The synth is the second one called First Mod.
It sure has enough modules to do something meaningful. Question is what exactly are you trying to achieve? Looks like you want to plug in some sort of guitar or similar. In that case you may want to have something to convert the pitch of your instrument / controller to CV so you can actually play your synth with it, such as the RS-35 . Also, there is a lack of VCA and mixer for my taste. Loose one the uZEUS and get a mixer instead. Did you notice, the guitar interface module seems to be DIY only.
	I have updated this synth to be a sort of guitar input unit/fully functional modular synth. Is it able to do a lot of things with this configuration?
