Can I use the Ardabil as a multiple?
Utility Module
http://www2.thisisnotrocketscience.nl/eurorack/ardabil/
click the link and read the description!!!!!!
if you are familiar with the Eurorack then it is easy to speak. as a beginner like i am you don't understand everything
you asked specifically can I use this as a multiple... basic reading skills and the ability to click on a link provide the answer!
if you'd asked:
does this
< Buffered multiple outputs
< Threads into three buffered outputs;
< source - the product description
mean I can use it as a multiple?
it would at least look like you'd done some research and don't just want to be spoon fed the answer!!!
so the answer is yes - you can, but if you want it for triggers, gates, cv and audio (and not v/oct) then it may be overkill - you just need a passive mult for those - buffered is only needed for v/oct (and in some cases where an output is expecting a buffered input - some make noise modules)
TBH - if what you want is a multiple - just buy a multiple - this appears to be massive overkill just for a mult!!!
or build one - really easy, if you can solder - if you can't it's really easy to learn - and a passive mult is a good place to start - and it's a very handy skill to have in modular synthesis - there are plenty of instruction videos on youtube - AISynthesis is great for beginner kits - like mults
Thx for this multiple info. I thought that the buffered multiple can both, cv and audio. Ok 👌🏼
Eurorack is really fun, my learning curve is always up, slowly but up.  in a few years I'll give you the tips;)
And I’ll follow the white rabbit to YouTube
if you'd asked:
does this
< source - the product descriptionmean I can use it as a multiple?
or build one - really easy, if you can solder - if you can't it's really easy to learn - and a passive mult is a good place to start - and it's a very handy skill to have in modular synthesis - there are plenty of instruction videos on youtube - AISynthesis is great for beginner kits - like mults-- JimHowell1970
And I’ll follow the white rabbit to YouTube-- Shapemodulator
you can use a buffered multiple for any type of multing - but it's 90%+ of the time unnecessary for anything but v/oct - ie from a sequencer to a vco
this is because you can get slight voltage drops when using passive multiples - which are irrelevant for anything other than v/oct (if you actually want to stay in tune)
I have a quite a few buffered (which I only use for v/oct) and passive multiples in my rack, but tend to use stackcables for passive multing
