Hi, I've just sketched a patch. I'm new into modular synths, but I think this could work well. Any comments or suggestions will be pretty much appreciated.
https://www.dropbox.com/s/75xhwy0210wcdy4/modulargrid_20204.jpg?dl=0
How are you getting the sound out of your rack?!
Hi, Tazio : ) Elements has stereo output, do I also need a mixer?
What I meant is how are you going to monitor your synth? Headphones/Speakers?
You might want to look into something like Intellijel's μJack or other similar products ;)
The questions as always is what do you want to do with it?
Also Elements is taking almost half of your rig. Have you seen MI's Rings? You might be happy with that and use the free space for other things.
You don't need Grids to trigger, you can use the burst-out or clock-out from the wogglebug. Or use Maths for both.
Elements is awesome, together with wogglebug you have a nice starting point (if you're into weird sounds).
Thank you Tazio and easyskywalker : )
I want to use speakers for the synth so, as Tazio mentioned, I will add the Intellijel's μJack. Removing Grids will add some room for that. I'm looking for evolving percussive sounds and I think Elements will work great on this. Rings strumming is awesome, though.
