This unit does not show the drawn current, even if its state is "approved by manufacturer.
Unfortunately the "edit function" on this module is disabled, otherwise I would have changed this mistake already.
I would like someone to advise.
Thank you!
blingistan
There is a "message the manufacturer" button. Maybe ask them? In the meantime you could share the current draw here in the comments :)
Hello, you are right. I should have done this. I forgot that.
So here I share the information the manufacturer shows on their website;
Approx. Power Rating: 210ma
I hope that helps, but it would be nice if the module gets an update so that the drawn current can be calculated in.
It's just my idea...
modulargrid
We don't change data when the lock is set by manufacturers. But if the manufacturer does not respond I will remove the lock.
