Advice? Feedback?
I've done patching in software programs and some semi-modular with a Moog DFAM and Werkstatt, but that's about it. I'm familiar enough to find my way around with a little elbow grease and googling, have learned a bit about how CVs work vs audio, gates and triggers, etc. -- but def. still amateur enough to expect some weird hiccups and things I didn't consider.
https://cdn.modulargrid.net/img/racks/modulargrid_1532287.jpg
I figure I'll work mostly with the Doepfer modules initially and probably the 2hps, as I get a better feel for how to patch everything effectively, along with the the 3 VCA/mixing and attenuator type units. Once I feel confident with my understanding of those, I'll start to pepper in the fancy lads one at a time, like the MS Ensemble VCO, Mind Phaser, Rampage, and Typhoon.
Anything you feel is missing or will be problematic or that I might prioritize? My goal, long term, is to explore pretty experimental meandering noise-meets-IDM type stuff. Like Autechre but more fun, say. Structured, playful, a little dramatic. Old material can be found in my blog at https://www.edwardewald.com/blog/
Thanks for taking a peek. Components broken out below. I'd love some on board sequencing and logic, that will probably come in the coming months, but I do have a DFAM, Werkstatt, an EM Clockworks, and a Rucci 16 step sequencer to work with externally, not to mention my PC, and an old Yamaha keyboard that has a MIDI sequencer, so I figured that'd be plenty to start in terms of just getting some things happening. I'd also like a dedicated white/colored noise source, but I figure I can snatch one pretty cheap on Reverb at some point. Beyond that I'll definitely be gravitating towards things like Pachinko and Chance (Qu-Bit), things that facilitate randomness and chaos, but in a controllable way.
If the Doepfer VCO and the MS VCO prove repetitive -- especially with the Mini Shimmery and Mind Phaser in there -- I might sell off one or two of those. I might also pawn off the BBD delay if the Typhoon covers everything for me, though I'm not amiss to the idea of playing with multiple delays, so... have to see.....
Anyway, all thoughts welcome thanks for looking/reading.
Mazzatron Testy Mazzatron Testy
Patch Cable Tester 1 2 HP 21 mm 1 mA 0 mA 0 mA
Mutable instruments Ears Mutable instruments Ears
Contact Microphone 1 4 HP 25 mm 5 mA 5 mA 0 mA
Doepfer A-111-2v Doepfer A-111-2v
High end VCO (Vintage edition) 1 14 HP 55 mm 70 mA 50 mA ?
4ms Company Ensemble Oscillator (Black Panel) 4ms Company Ensemble Oscillator (Black Panel)
Black panel for the Ensemble Oscillator 1 16 HP 25 mm 114 mA 45 mA 0 mA
2hp Brst (Black Panel) 2hp Brst (Black Panel)
Voltage Controlled Burst Generator and Trigger Delay 1 2 HP 42 mm 26 mA 7 mA 0 mA
Doepfer A-121-2v Doepfer A-121-2v
12dB Multimode Filter (Vintage edition) 1 8 HP 50 mm 40 mA 40 mA 0 mA
Doepfer A-141-2v Doepfer A-141-2v
Vintage edition panel version of the A-141-2 ADSR/LFO 1 14 HP 70 mm 40 mA 30 mA ?
Doepfer A-188-1v Doepfer A-188-1v
Bucket Brigade Delay Module (Vintage edition) 1 14 HP 60 mm 80 mA 50 mA 0 mA
ADDAC System ADDAC216 ADDAC System ADDAC216
Sum & Difference 1 8 HP ? ? ? ?
Blue Lantern Modules Mini Shimmery MK2 Blue Lantern Modules Mini Shimmery MK2
Percussive Metallic Generator 2 10 HP 64 mm ? ? ?
Hexinverter Électronique Mindphaser Hexinverter Électronique Mindphaser
next-gen analog complex oscillator || thru-zero phase modulation in the analog realm 2 30 HP 24 mm 110 mA 100 mA 0 mA
2hp S+H (Black Panel) 2hp S+H (Black Panel)
Dual Analog Sample and Hold 2 2 HP 42 mm 5 mA 5 mA ?
Befaco Rampage Befaco Rampage
Dual Sergesque Slope Generator with Logical Crossfading 2 18 HP 30 mm 110 mA 90 mA 0 mA
CalSynth Typhoon - Black aluminum CalSynth Typhoon - Black aluminum
Expanded Clouds with sliders 2 16 HP 25 mm 160 mA 35 mA 0 mA
Doepfer A-135-2v Doepfer A-135-2v
Quad VCA / VC Mixer (Vintage Edition) 2 8 HP 45 mm 40 mA 40 mA 0 mA
Doepfer A-138sV Doepfer A-138sV
Mini Stereo Mixer 3 8 HP 30 mm 10 mA 10 mA 0 mA
I don’t think you should see the Doepfer BBD as a normal BBD delay. If I’m right there is no filter for the BBD clock noise, which is an awfully harsh sound that lowers in frequency as you lengthen the delay time. So if you’re using it as a normal delay, make sure to add an extra lowpass filter just for the feedback path of the delay. It’s an amazing creative module for time-based fx and karplus strong synthesis, though - and if you decide to get the extra filter, it’ll be an extremely flexible delay!
Apart from that, the usual stuff people forget: attenuators, mixers, VCAs. There are quite a few sound sources in this rack, you’ll need ways to control them. I have only 3 monophonic sources in my current rack, and about 10 VCAs, 4 mixers and 3 attenuators. But if you start with purchasing the voice that interests you the most, you’ll find out on the way! Just don’t buy too quick and take the time to get to know your modules :)
OP: please post a link to the actual public rack - so we get click-through and infomatics - jpgs are next to useless - for helping us help you!
my basic thoughts echo @LYFoulidis
I would strongly suggest doing a lot more research before starting buying anything!!!!
at the very minimum: read through some other newbie threads - see what others have been advised in similar situations (there are thousands and thousands of these - you may be special, but you are not unique!)
I heard something about this, but ... we'll see how it goes I guess. I'm more interested in experimental and interesting sounds than standard FX, so it should be fine. I've actually tried to sort of order more than I may need in some respects while I have the opportunity to do so, figuring some will be traded or sold off depending on what kind of workflow I find myself falling into and which units I enjoy the character of the most. Polished certainly isn't always my pref. I had a Korg SQ-1 sequencer, and a Rucci 16 step sequencer, and recently had to trade one off ... I opted to part with the SQ-1. It does way more than the Rucci, which is purely CV and a little wonky, but I just enjoy working with the Rucci, it does what I want and has character and charm.
-- LYFoulidis
Hmm, thanks for the tip. Those are startling numbers to be sure. I've heard people tend to underestimate the VCAs they need, but I thought between the Quad VCA, ADDAC unit, and the Mixer I might actually be overdoing it. I might have to reprioritize a bit.
Do I just copy/paste the URL? Guess we'll see if that works:
(Hmm... I can't get it to show the right one. It keeps showing an old version. I'll try again later.)
Actually the .jpg in the initial post is of an old version of it too, but ... I guess that's still the gist of it.
I do get that I have way more sound sources than I need, there were a couple things I happened to get a good deal on and just wanted to have them. I'll probably just work with one of the sound sources to start until I learn more.
if you have problems copy and pasting the rack let me know which one and I can try!
that sounds like a plan - I'd try to spend a few weeks to a month with each one and then with a couple together etc until you know all your sound sources and all your other modules inside and out - this will help give you an idea of what else you need to get everything working together in the future
How to correct a public posting with a rack link:
First, delete the original link out of your thread.
Next, go back to your build's page. Refresh it. Then open the "Screenshot" under the "Show" menu. If this doesn't show the right version of the build, refresh the screenshot. If it STILL doesn't show it, go back and check the build. Then refresh again, do the screenshot again.
Once the screenshot AND the build are identical, go back to your original post and put the link to the BUILD PAGE (and NOT the screenshot) back in. When you go back to the thread this time, you should see the image where the link was replaced in the post.
User left
Always get a bigger case/power supply than you think you will need! I started small with 6U case but realized that I needed a monster base case with 12u monster case after a year.
