Hi there,
my TM seems not to be working properly: there is no more pulse coming out of the pulse out.
We agree that the pulse Led should be blinking according to the current pattern, right? I have no blink and it's impossible to trig anything from it, as I think I used to. (Whether I plug a cable or not into the pulse out, it doesn't blink.)(I already switched off and back on the whole rack, doesn't work).
Please see video here:
What do you think I should do?… Thanks!
GarfieldModular
Hi Left4deaf,
Did you check already the connectivity of power cable on both sides, hence at the module side and at the power bus side? If no signal, nothing at all, it might be a power issue.
Good luck with the troubleshooting and kind regards, Garfield Modular.
Thanks GarfieldM for your comment. I checked both and plugged it on another busboard, but it still doesn't work properly… :•(
