havent heard about this mixer before,have anyone used it?
was thinking about getting a ES-9 to be able to record into my DAW,but seems this could beused for the same purpose
https://patchwerks.com/collections/mixers/products/blood-cells-audio-d-o-mixx-mono-to-stereo-mixer-with-direct-outputs
I'd read the spec again - it's a mixer with outputs for each channel - which is really handy - especially as they are post fader
it could be used to feed nicely into an es9, but not an audio interface
ahh so i still need the es-9?i cant just connect the outputs of the mixer to inputs on my presonus studiolive 16,0,2,the studiolive is dc coupled?
well you didn't mention that you had another audio interface - sorry mixer - why not just go straight into that then and bypass the mixer and the es9?
if it's audio it doesn't need to be dc-coupled - that is just for cv
ahh yes my bad:)well the thing is my case is a 13U travel case,only use the studiolive in the studio,and like eeryone im hoping to one day be able to play live again.
so it is possible to use this mixer with my presonus,so i dont have to get the es-9?if yes i just need some cable to connect theeurorack mixer to the presonus
yes, you just need the correct cables 1/8"->1/4"
thanks for the help jim,much appreciated
baltergeist
Hmmm.... this could replace my 2hp VCAs. Thanks for the heads-up on this!
Inscrumental music for prickly pears.
-- baltergeist
no problem,gonna order one this week
