Some simple more deliberate patching this time.
Used a stacking cable for the FM receiver which I jacked into the Cutoff for the Spectral Devastator and into the CV input of the Worm.
Worm went through the filter which was in it's turn is connected the ADDAC300.
The result is...unpleasant.
GarfieldModular
Hi TeenageLarvae,
Ha, ha, sounds to me like a radio that has been broken ;-)
By the way, I only hear your noises coming through the left channel, is that a wanted result? Kind regards, Garfield.
Hi Garfield,
Thanks for the comments and kind words.
Seems like it comes out of both channels when I record but it only comes out of the left channel once I finish and press play.
I'll look into fixing it for next time, did some research but couldn't find a proper solution.
TL
GarfieldModular
Hi TL,
Sounds to me that there is something rotten in the state of Denmark ;-)
Good luck with the troubleshooting and kind regards, Garfield.
klodifokan
The result is very pleasant.
Continue.
