the next step i want to do is multitrack record my Eurorack system into Reaper,for further processing finaliing,would getting a Expert Sleepers ES-9 usb interface be the easiest way?
it's definitely one of the easiest ways - if there is more than enough i/o and you don't already have an audio interface and you have spare rack space then it's probably a good buy for you
If the objective is to get the audio back into the DAW with the least hassle, yes, go with the ES-9. It'll also open up some possibilities for controlling the modular via the DAW IF you can get Reaper to speak proper CV/gate/trig/clock outputs. I would presume that the ES-9 comes with a copy of Silent Way, though, so the big question isn't so much whether the ES-9 will work, but whether Reaper and Silent Way can play nice with each other.
silent way is an optional extra
awesome guys,thanks,the ES-9 will fit my needs perfectly
Hah...so it is. Although...you'd think that Expert Sleepers would toss a copy in with modules that use it. Would definitely be a plus for them, as having the total package on hand would likely get more users interested in this sort of control method.
