Hi,
I own some semi-modular synths, such as Lifeforms SV-1, Moog Grandmother, Mother 32, 0Coast, and the Neutron.
I would like to add some extra modules to expand on them, but use the semi-moldulars' oscillators, filters, envelopes and audio outs.
I just bought an intellijel Palette 62HP, because I want to try a little Eurorack.
I read it's hard to do a small palette well and don't want to waste money, so I thought I would run things past experienced people.
I want a generative krell type palette with some musical potential, to tame chaos a little with a quantizer.
Before I buy anything more I put together some of the modules I'm interested in.
Any advice and things to think about and to beware of would be great.
Also any advice about what might be good for the smaller 1U row would be great.
Many Thanks
Generative != small. And why didn't you implement anything in the tile row?
I wouldn't have bought this cab for this purpose, frankly. Generative tends to imply a sizable network of interlinked control systems which act on each other at different orders of systemic control. It's not even exactly easy to do effectively in a 2 x 104 cab, although you can get there by totally compromising your ergonomics and cramming the case full of small modules. I understand that the point here is to try and put together a small "sidecar" for the generative processes...but honestly, you're not even close to where this should be.
@Lugia undoubtably knows more than me, but from recent explorations of my own I think it's possible to build at least a generative melody box in 62HP, so I took a crack at it, see below:
I left the Wogglebug and the Marbles, they seem great, but pulled out everything else. We're coasting a lot on the power of Marbles (for example we don't need a quantizer, it can do that for us), but that's ok, it's a powerful module! So, to review:
1) Shifty lets you route the output of one of Marble's melodies to up to four different synths, and has gate triggers which can be used for envelopes and/or for manipulating other parts of this rack. Want two synths to add some harmony while others handle the melodies? Shifty can help out here.
2) Switchblade lets you toggle different inputs, for example want to alternate the Deja Vu input into Marbles from an LFO or a Sample and Hold? Switchblade can help you there.
3) Ochd provides 8 long running LFOs, that can slowly shift different CVs around your system. Want long, slow change over time alongside a little more busy-ness? Ochd is your module.
4) Sample and Hold is pretty useful for generative work, RND Step gives you 3 sample and holds normalized and with pink noise sources if you don't patch them. This is a great control tool and a random source alongside Wobblebug.
5) Adding a Slew Limiter gives you a lot of new terrain to explore, so I added a Time Warp. Using this you can for example have the gate triggers from Marbles turn into smooth, rolling CVs that will stay high if there's lots of notes and will drop down if Marbles quiets down. It can also be used as an envelope generator, triggered by gates around the system. Even better, it's gate-able itself, so other modules can control when WMD fires off.
6) Speaking of gates, the Rotating Clock Divider lets you take one gate and create rhythms around it. If we're making ambient rhythm might not be the first thing that comes to mind, but this will help take output from e.g. Shifty/Marbles and create a sense of movement or complexity around the system, triggering an envelope to adjust a filter somewhere every so often, or toggle a Switchblade switch, stuff like that.
7) Hyrlo, smaller 6 channel mixer, will help you collate all your synths together.
8) We've gotta have reverb for generative ambient, FX Aid does a ton on top of that so it's a no-brainer in a rack this size.
For the 1U tiles, I added
1) a Quadratt so you can attenuate different control signals
2) a dual VCA to make more complex control signals
3) an oscilloscope so you can understand what's going on (surprisingly important!)
4) an LGP to let you do a little signal volume control here in case one of your outboard synths doesn't have VCA control.
One important note: I only picked modules that I felt you would still want were you to expand down the road. Everything here is small, yes, but also powerful and could hold its own in a rack of any size. So if you start here and find you really do want that 2 x 104HP rack you can just port some of this over.
Anyway, that's a lot of text, hopefully some of it's useful!
Thankyou @Lugia @troux
This gives me a lot to think about. And thanks @troux for taking the time to write all that. I'll be cutting and pasting it into my notes to read it several times in the course of saving money and buying modules.
NP @Cristoppano, let us know how it goes!
