utilities - just like almost everyone else who has to ask!
Ok, thanks. do you have some special in mind?
matrix mixer, sequential switch, kinks, logic and quite frankly all the other ones, it really depends on you
have a look at a few different types and try and work out how you would use them - particularly for modulation purposes (sa you mention that) - extending what you already have in more interesting ways than 'just getting another eg/lfo' by mixing, modifying, multing and switching
my other suggestion would be to spend the money on the next case - then you really won't care about the fact you only have 14 hp left
Actually, I see a problem here...first up, that Erica mixer in the top row seems like it does too much and is too big for a source submixer. Also, it has a compressor onboard...but you ALSO have a compressor module in the bottom row, and that can get dicey when trying to set up levels in a modular. And you're eventually heading for a stereo image by the time you're hitting your output stage.
Do this instead: pull the Erica. Replace it with Doepfer's Mini Stereo mixer, then add a second stereo mixer for the drums in the middle row. Once that's done, the FIRST mixer should feed VCAs #1 and 2 in the Veils, and the SECOND should feed #3 and 4. After that, then patch the individual VCAs from the Veils to the two stereo inputs on the MakeNoise crossfader, optionally using the FX Aid XL for the 1/2 feed and the little FX Aid for the 3/4. This way, you're in stereo once you get past the sources, with VCA level control all the way to your output via the Veils' VCAs.
