I'm downsizing from a large Modcan system, and slowly getting my 208HP Euro together.
Doing mostly slow evolving soundscape type stuff.
Here's a really old track using the Modcan to give you an idea. Current work is a little more calming and peaceful. I was much angrier back then ...
Don't really need audio effects (Clouds ....) effects modules in the rack - using an external Empress Zoia and some Eventide ...
I've already got about half this system up and running. Also have a 0 Coast/Control to go with this.
Just out of curiosity, what seems to be my most "missing" areas at this point?
here's the link for anyone interested
it maybe a good idea to differentiate between what you have and what you think you want - maybe that's what's happening - one image is displayed in this post and the link displays another - I guess you have tempi, rene, quadrax, veils and plaits? and want the others - if so why replace veils with intellijel? unless it's based on availability
i would probably add some logic, mixing for modulation (matrix mixer, another cascading vca - or possibly a matrix vca!), an envelope generator (zadar perhaps), a wavefolder, possibly some effect pedal interface modules - depending on the pedals - I have some that can cope with modular levels
i wouldn't rule out effects in the rack completely - there's nothing to stop you, for example, adding a load of reverb to a sound before hitting a vca and/or filter, then sending that to your end of chain reverb too - same with delays - also the modulation possibilities - unless of course your outboard effects can be controlled with cv, idk - same with clouds - you can use it as a vco - record something into the buffer and freeze it - granular oscillator - just because a lot of people use it as an end of chain stereo reverb, doesn't mean that's all it can be used for - not that I am particularly recommending it - just pointing out that it can be used for more than you may think it can - saying that I would probably add an fx aid xl
Weird - why is the rack showing in the post different?
Let me see if I can fix that ....
Hmm - regardless of what I do, it's not showing the full rack in the post - neither is the link you posted.
Copying the link directly to another browser works fine though. Looks like we have a forum bug maybe ...
yeah it's already been noted that links aren't working properly - blank or this by the look of it!
User left
Maybe add a filter and attenuator?
