BEEQ
Portable Suitcase with 2 x 84HP + 4MS Pod64x
Designed for minimal and rythmic CV modulation.
Hands on sequencing:
- Frap Tools USTA
- Noise Engeneering Memetic Digitalis
- Acid Rain MAESTRO
Sound Sources:
- 2HP Kick
- Noise Engineering BIA
- WMD Chimera
- SSF Entity Percussion Synthesizer
- Frap Tools Brenso
Clocks & Function Generators:
- Mordax DATA
- Frap Tools FALISTRI
Effect & Filters:
- Noise Engineering Desmodus Versio
- Erica Synth Pico DSP
- Mutable Instruments Ripples
User left
Looks pretty good maybe add in a quad VCA and logic module?
BEEQ
Thnx for the advice. I'll keep a watch on that.
Brenso, Entity and Ripples have a internal VCA with VC control.
I use the Frap Tools 321 for balance in te mix for BIA and Chimera (also with internal VCA)
On top of that the 2HP double VCA...
Any advice on a good Quad VCA?
User left
Sure, I like the Intellijel Quad VCA- small and powerful with boost and attenuator controls.
I've been building something similar but different for Acid, and I'm curious what you're using for your drum sequencing here, does the Maestro handle that?
