endlessdoodle
In order to be able to change settings of the EMW 8-step trigger sequencer while running, I patched a circuit that holds and resets the module in case it is out of sync. This only works for forward mode.
With the inverters of the Doepfer logic and the Malekko gate combiners I made a flip-flop. I took step 1 from the Doepfer clock sequencer and lead it to the trigger modifier. The logic comes down to this. If not step 1 and EMW sends 1-step pulse, then the flip-flop will set and the EMW hold input is positive. If step 1, the flip-flop resets and the EMW starts running.
Next the EMW has to be resetted. The reset takes place at the up and down change pulse of step 1. (Out of trigger modifier)
