Somebody knows if this module saves the midi learned messages, then powered off-on again? Thanks!
8 Channel Midi Converter
http://leipzigwest.org/?page_id=242
Yes it does.
Thank you! Great module!
Hi quick question, if the module is receiving different not lengths from say an Octatrack would it output different pulse widths (gate durations) on the gate outputs? cheers
hi, yes, it does!
thanks!! :)
Wouldn't it be great if you could send monophonic sequences to each of the channels. Dang, you'd have 8 channels note to CV for instance coming from a DAW...
It does what it does.. the module is relatively cheap cos I never really had much additional dev work with it.
While a (Pitch-)CV/GATE mode would be possible: I'd need to develop a way for customers to calibrate their modules themselves.
That takes time and I rather work on other projects. Doesn't mean it will never happen.
