henrix_iot
Firmware images can be found on our website.
We recommend to upgrade as soon as possible for best experience.
Install instructions:
1. Power on 2.4SINK Eurorack module in WiFi access point mode
2. Make sure no sensors are connected
(either wait 10 minutes until sensors go to sleep or take out batteries)
and no Ableton Link enabled device is in the same WiFi network
3. Access web app with a web browser (http://2-4sink.local/ or http://192.168.5.1/)
4. Click firmware upload button and select firmware binary 2.4SINK-vX.X.X.bin
5. Wait until upload progress has finished and module has rebooted automatically
6. OPTIONAL: Verify firmware version in web app below upload button
ATTENTION! ALL SETTINGS INCLUDING WIFI, BLUETOOTH AND MAPPINGS WILL BE DELETED AFTER FIRMWARE UPGRADE!
After successful upgrade, the module starts WiFi in access point mode with default settings (SSID: 2.4SINK, no password).
By default, all outputs of Bank B are configured for Ableton Link after upgrade
(clock for full/quarter beat clock and LFOs with different waveforms synced to single beat).
CHANGELOG
v1.1.0-beta2
Bug Fixes:
- Fixed firmware crash if many Bluetooth devices are in the near
- Fixed Bluetooth MIDI connection loss
v1.1.0-beta1
New Features:
- Ableton Link (including customizable clock divider and synced LFOs for each output)
Improvements:
General:
- Up to seven Movesense motion sensors can be used in Wi-Fi client mode now
- Higher randomness for stepped noise LFO
Performance:
- Improved performance of Movesense motion sensors
- Improved performance of web app
- Overall stability and performance improvements
Usability:
- Direction of acceleration axes match graphics on sensor
- Gate/Triggers based on acceleration are debounced to prevent unwanted triggers
- Yaw axis value increases when turning right (inversed direction)
- Removed netmask and gateway field in web app for WiFi access point settings
- Status LED is now flickering if motion sensors are connected (depending on number of sensors, the frequency increases)
- Status LED becomes brighter representing the upload progress during firmware upgrade (if firmware upgrade was successful, status LED blinks five times)
Bug Fixes:
- Fixed disconnect of Movesense motion sensors when changing CV settings via web app
- Fixed non reconnect of Movesense motion sensors when rebooting module
- Fixed disconnect and non reconnect when using more than four Movesense motion sensors
- Fixed wrong mode when changing and saving output mode gate via web app
- Fixed phase offset of some LFOs
v1.0.0
Initial firmware
