Right now my plan is to record my Modular into Reaper,it works great,BUT if i want to record from Modular into Reaper at a certain BPM,What Modules do i need for that?is Pamelas new Workout enough?
any help would be appreciated
if you look around enough (2 mins on google) you'll find a pulse from make noise that you can just copy in an audio track and then place it on every beat and play that out at full volume on a spare audio channel - this works even if you don't have a dc coupled audio interface - I do and I still use this method
or you could use midi clock and a midi->cv module
how would that pulse help me record audio from the modular into Reaper at a certain BPM?
use it as the clock - send it out on say channel 3 of your interface and set the tempo in reaper
if you are going to make several passes it can help keep everything in time - especially if you want to change tempo during a track - set the tempo changes in the daw you can also use it to start/stop etc - hopefully when you record then every track you record from the modular will start at the same place which makes life a lot easier
if you are going to want to add soft synths or any processing that is time based in the box
if you are adding to something already recorded
etc etc
so i actually dont need any modules for this?
no just the appropriate cable - that is your clock at the correct bpm
then just record the modular via your audio interface
