any thoughts on this rack? open to any and all suggestions
farkas
I see that you have already changed out most of the modules pictured here. What are you wanting to accomplish music-wise? It looks like you are going for the generative ambient sound with the modules pictured here. In this rack, I would think you will want at least a quad VCA to CV volume/amplitude.
It's not going to be very fun to work with all of the 2hp modules you have in your other build, modulation-wise or workflow-wise. I'm a fan of larger modules with more modulation options. Modulation weirdness is the fun of modular, and many of the 2hp modules don't give you a lot of options.
Have fun and good luck!
@farkas, just updated the case if your down to take a look
farkas
I think if I was dead set on the micro Mutable clones and 84hp, I would go with something like this:
You still haven't mentioned what kind of music you are trying to create, or given us any idea if you have any other gear to pair with a modular, so this is all just guesswork. First and foremost, I would recommend buying a larger case than you think you currently need though. That would be the first universal piece of advice I could give.
@farkas, sorry I didnt clear things up before, I am a hammered dulcimer player (primary instrument); my live and recorded work usually revolves around pre-recorded dulcimer samples which are converted from pitch to midi via ableton then ableton is used to sequence an elektron analog 4 MKI. I have a bunch of external piezo mic'ed gear which makes me think I want some pre-amp modules like the ears. I make ambient music and was looking to put together a small generative synth for my first eurorack setup. Since becoming more knowledgeable about my current system (pretty much everything besides the micro plaits and disting) I am realizing that I need more space to build the machine which can match my required level of modulation and expression. Thanks for the help, will be building a bigger case...
farkas
Ah, that sounds like a great combination of instruments. In that case, I would definitely get something like the Doepfer A-119 or a similar mic/instrument preamp with envelope follower. Rings and Clouds would likely both be really fun with a dulcimer.
I've been using two of the TipTop Mantis cases (208 hp each) along with two Make Noise skiffs (104hp each), and I would highly recommend the Mantis in regards to value for money. They have been having trouble with low stock, but I'm sure you could find one soon.
