on vacation right now so cant try out untill friday.
i want to record my modular into my Daw(Reaper) for my soundcard i use a presonus studio live 16.0.2,in my modular i have a Ladik M-171 Pannable Mixer,can i just connect cables from the M-171 into channels on the studiolive,choose those channels in Reaper and then record??
Yes you should be able to connet the Outputs from your module into the Ins on your mixer just like any other instrument. I have not used Reaper but assume you just set up the soundcard connections and select the audio channel with the module on it - at least that's how I would do it in Cubase.
Just do a couple of test records to make sure audio is coming though on the correct channel before getting too involved (I have done this before and wasted a whole session by not having the correct line selected).
for some reason i cant see the reply?
modulargrid
-- Broken-Form
The post was auto flagged as spam for whatever reason. Changed that.
