oliodnb
Hi everyone,
I'd like to connect two cases with a single cable (or two if going with the Doepfer) but I'll be sending mainly audio between them.
I'd prefer the Plum Audio's Rack Plumber HD as it has the most connections, but I can't find any feedback on how well it works with audio signals. The two cases are pretty close to each other so the cable length shouldn't be an issue.
Does anyone have any experience with this kind of modules?
Thanks.
GarfieldModular
Hi Oliodnb,
I am using the Doepfer - A-180-9 and so far so good but I have to admit that I still have to test it with full usage of all possible channels/lines and then see if there are any interferences. What I did is that I am using CAT 7 cables to avoid as much as possible the interference issue.
With other brands and possibilities I don't have experiences.
Kind regards and good luck, Garfield Modular.
Hey there :) I searched for this topic, to ask if any of these kown brands and ethernet based modules of this kind have any better or worse signal bleed that I have come to be aware they can have?
Thanks!
GarfieldModular
Hi Pspiralife,
I still have good experience with those Doepfer - A-180-9, I have several cases that I connect with these modules. I am using meanwhile CAT 7 or CAT 8, and I guess because of that I have no issues with interferences or bleeding.
I think Intellijel has similar modules in 1 U as well, they look very similar, so you could consider those too.
Good luck and kind regards, Garfield.
