Correct me if I'm wrong, could you take an ALM S.B.G. with it's expression output, and then connect that to a boost pedal with expression in, say, the Supro boost, and create a VCA by sending an envelope through the S.B.G. into the pedal?
Rookie. Learning Guitar. Will one day build a rack.
Sort...of. It would depend on how the Supro's circuit responds to a CV. The idea is sound, but the question would really be what sort of response curve the pedal is likely to have to linear and/or exponential CVs. Also, will 0V actually result in a full level shutdown, or does the audio level being controlled that way only go down to a certain threshold?
Just a thought I had. Even if it didn't work in a synth voice, it could make for an interesting tremolo I guess.
Definitely. And naturally, there's no reason to not try it. You might also try feeding an audio-frequency signal to the expression input and see what that does. You might find some twisted new AM method!
