hi there i just wanted to know how come when attach the module to the power supply it all go hay wire
Hi Modsquadbaba2020,
Did you check if the power-flat-cable -12V was connected on the correct side of the module plug/connector and the same for the power supply side? If you are sure about that, then that's strange indeed. Any more details on what exactly happened and what you did?
