60 mA @ +12 V
56 mA @ -12 V
0 mA @ +5 V
Versatile Multimode VCF + Phaser
https://intellijel.com/eurorack-modules/polaris/Thanks for that info. How did you measure those values / where did you get those specs?
The Intellijel module entries are controlled by them now (hence the manufacturer approved seal) so. Only they can change the info now.
Hey guys i got a question. I just got a new one from MusicStore in Germany and the Panel looks different (for example; the MultSwitch is silver and there is no circle around the cutoff), dose that mean it's a newer version or older? im confused.
greetings Figo
Hi Figo. It looks like the version pictured above is the original faceplate as submitted by Intellijel a few years ago. The version currently pictured on their website is like the one you described, so I would guess that you have the newer updated cosmetics.
Hope that helps.
