Hey,
Here is the current rack I have built up over the last year or so. As far as power do I need another power source or is this sufficient for what I have. Additionally, I have always run audio out from the Quad VCA to my Computer Interface for recording, but I usually get some unwanted noise in the signal utilizing an 1/8 - 1/4in cord. Is this due to power problems, or am I in need of a utility module to help with outputing audio to my computer interface.
Thank you!
GarfieldModular
Hi Heard,
You definitely need an audio (input/) output module. The audio levels of modular are not the same as audio line levels.
But if that solves the problem you described, I am not too sure. If you look for a small, reasonable audio output module, you might want to have a look at the Beface Out v3 module, that one is small in size, has a headphone option and gives you stereo output at the usual audio level.
