Early Dec: Put the IKEA Rast on my Christmas list. Should be a slam dunk since it's cheap.
Dec 18: Power One HCC-15-3 is here.
Dec 19: Picked up a switch that's lighted, both when on (green) and off (red).
Dec 21: Ordered a set Vector rails (enough for 6U @ 104 HP), a fused (1-pole) IEC socket, and then ordered some IDC connectors for DIY wiring up some 22 gauge power cables for the modules in my system.
Dec 21 (update): Just started my system with a Doepfer A-119 envelope follower module!
Dec 22: Picking up M2.5 hex nuts and M2.5 x 6mm bolts from the local Grainger.
Currently working on:
Seriously considering going from the Power One to a fuse block to aluminum distribution bars, ala Hinton Instruments. Need to do some research on this, if there are any active components that are needed beyond the PSU or not.
