Guys, i currently started building a small modular setup and already have both A4 and OT.
Would it be best to sequence/control the modular with A4 or should i get a midi to cv module (mutant brain) and use OT?
GarfieldModular
Hi Gilera,
Bit difficult question to answer on the other hand... the A4 got already 4 outputs (CVs/gates), so why not taking this the easy way and start to work with your A4 (Elektron Analogue Four) as the unit that controls your modular system and save for the moment the money for a MIDI to CV module.
If you then after a while realise that perhaps those 4 outputs aren't sufficient then you still can start to use your OT (Elektron Octa Track) via MIDI and with a MIDI to CV module. At least if the A4 seems to be sufficient, you save yourself the trouble of finding a good MIDI to CV module as well as the money for it :-) And by the way... if you want to utilise your OT fully... you need at least a module that can handle simultaneous 8 MIDI tracks... most modules only can go up till 4 tracks though, so you need already to MIDI to CV modules, saving even more money if your A4 is sufficient enough. I therefore would try to start this of with your A4 first and see if that's enough.
I don't know the Hexinverter Mutant Brain module very well but from the information I have read, looks like you also can go up till 4 channels simultaneously, perhaps with a few tricks a few more channels, not sure. Another module to consider and that I am using is the Vermona qMI 2, a very nice logical module to use and up till 4 channels, each channel: gate out, 1V/oct, and 2 CVs out, beside that also clock out. I had for a short while the Doepfer A-190-5 but somehow I didn't feel that module was logically to use at all, difficulties with the menu (understanding) and I exchanged it for the Vermona, and that was so much easier and better. It's a pity because I actually do like Doepfer modules. I got quite a few Doepfer modules and I am happy with them, the A-190-5 is so far the exception.
By the way... if you got already an A4 and OT... why do you still need modular? You got already two lovely nice devices :-) !
Kind regards and good luck, Garfield Modular.
blingistan
I don't wanna get into why one would want/need any of those devices.
It just so happens that I use an OT, an A4 and a modular rack. Both Elektron devices offer unique ways to control a modular. It depends on your modules and what sparks/stifles your creativity on which approach is best for you.
A4 not only offers note CV, gates and sequenced manual cv, but also LFOs and envelopes. All of them plockable. Really cool.
The OT needs a Midi to CV module (like Garfield mentioned). There's no need for an 8 channel interface. You can absolutely use the OT to control just one or two channels. It's hard to recommend a single interface without knowing what should be controlled. Multiple voices using just note cv+gate? Or rather one voice with lots of midi CC to CV? The expert sleepers FH-2 is very flexible, but requires quite a bit of setup time and planning. Something like LPZW's Tram8 offers 8 gates plus 8 CVs (in a special OT optimized firmware), but no note CV at all - might be totally sufficient for a drum rack, or for sequencing eurorack sequencers via OT.
