To Expand Moog Grandmother...
01A: MIXED VOICE PLAY OVER TEXTURE LOOP
Arbhar with Phone recordings through Mimeophon
Plaits into Grandmother with grandmother keys
Reverb possible with Disting
01B: TWO VOICE PLAY AND SEQUENCE OVER TEXTURE LOOP
Same as 01A, but Plaits with sequencer and Grandmother with keys
Pre-mix Plaits and Grandmother with Disting
01C: DRUMS (AND PLAY) OVER TEXTURE LOOP
Same as 01A or 01B, except drums with Plaits
02A-C: PLAY/DRUMS DELAY/GLITCH OVER TEXTURE
Same as 01A - 01C, except Plaits/Grandmother through Mimeophon
03A: PLAY OVER TEXTURE DRUMS
Arbhar with Phone recordings to make texture drums
Plaits into Grandmother with Grandmother keys
Either channel into Mimeophon
03B: TWO VOICE PLAY OVER TEXTURE DRUMS
Same as 03B, but Plaits with sequencer and Grandmother with keys
03C: DOUBLE DRUMS WITH GLITCH
Drums with Plaits
Everything into Mimeophon for glitch, pre-mix in Disting or send L/R
04A: ALL BUS INTO MIMEOPHON LOOPER
Plaits into Grandmother into Arbhar into Mimeophon as looper
Either build Arbhar textures with Plaits/Grandmother and play wet/dry
Or play wet/dry over pre-buffered Phone input
04B: TWO VOICES INTO MIMEOPHON LOOPER
Plaits into Grandmother into pre-mix with Disting
Arbhar (mono) with Phone recordings into pre-mix with Disting
Disting into Mimeophon as looper
05A: FEEDBACK AMBIENT
Arbhar Microphone input or pre-buffer anything
Send L of Arbhar to Mimeophon and R of Arbhar to Mix
Send L of Mimeophon to Mix and R of Mimeophon back to Arbhar
05B: FEEDBACK AMBIENT ALTERNATE (MONO)
Send Plaits through Grandmother into L of Mimeophon
Send L of Mimeophon into Arbhar (in Follow Mode)
Send L of Arbhar int R of Mimeophon
Send R of Mimeophon to Disting to pan, then to Mix
Plaits or Grandmother could alternatively be a separate input into Mix
You might want to consider a dedicated mixing module. I would start with that and then add in other modules. I would suggest something with a stereo output as well as line level outputs. Trying to find a way to adhoc signals together with each and every patch is going to be difficult and cut into your creativity. Getting signal to a dedicated mixer will be much easier on you creatively.
To expand a bit on Ronin...this is a situation where a suitable mixer is pretty essential. Instead of looking at them as a way to combine audio together, look at a performance mixer as a control point where you have several "instrument" patches like the above already prepatched and ready to shift from one to another by bringing channels in and out. This avoids your having to repatch constantly, makes the above concept work for both studio AND live.
However, I have some concerns about the size of the build. To get the above idea to work really well, you'll need to have space for a proper performance mixer, for a few extra modules (notably attenuverters...you can wring a lot of control power out of 'em, even if they're boring and unsexy) to assist in controlling activity in the subpatches, logic and timing modules to complicate the trigger/gate situation, and so on. It's an ambitious idea...but the fact is that 2 x 104 cabs are easy to get and cheap (often as cheap as some higher-end 1 x 104s), or you can add a bit more potential with a 7U cab that gives you some tiles and, potentially, cab integration if you go with Intellijel's 7U 104 hp case.
One last warning...don't think you'll be able to send the Moog's line output back into the Eurorack mixer directly, because you likely won't get a usable result due to the major voltage differences. It either has to be preamped first...or just don't do that, and mix it as per usual along with the modular on a typical small mixer. The latter is cheaper, fyi.
Thanks for the input Ronin and Lugia. Those are great points, especially considering I am building this to play live...well just to myself in headphones. I'm only learning.
The grandmother has a modular level output, so it doesn't need to be preamped.
