ziddabit
Hey,
fyi - the Euporie filter is planned to be available in January 2020 (along with the Sinope Dual VCA).
We are hoping to complete some sound demos in the next few days... :)
Questions? Feel free to ask in this thread (thanks to the person initiating this thread)
Some further infos:
Four Pole LOWPASS VCF with Moog and Sallen&Key Resonance
Powerful Sound from sweet to overdriven with lot of character
Simultan 24dB, 12dB & 6 dB Filter Outs
12dB State Variable Highpass Input Switch (150Hz)
Linear Resonance Distortion and Input Gain Stage,
Make up Gain (Bass Boost) for Moog Style Resonance
Linear FM Input for Audio Rate modulation and Resonance CV IN
Keytracking In with 1V/Oct and Attentuator
Two exponential INs with Attentutators and CV THRU Outs
Update 10. January 2020:
have done some sound snippts for your enjoyment...
GarfieldModular
Hey Ziddabit,
Interesting module this filter. How to switch from Moog to Sallen & Key and vice versa? Is that done with the A/B button?
Are you representing the IO Instruments new setup?
Good luck with the startup and let's hope you will be as successful as for example Erica Synths or Intellijel :-)
ziddabit
Greetings GarfieldModular!
Yes, you are right. The A/B switch will toggle between Moog Ladder and S&K resonance characteristic.
The top switch is for the variable highpass (to thin out the low frequencies from the incoming signal, if needed).
And yes, I'm one of the co-founders of IOI.
Thanks for your wishes. I'm sure we will find our path the one or the other way.. ;)
Regards, zid aka Frank
GarfieldModular
Hello Frank,
Do you have already an accurate date when the Euporie becomes available? I am quite keen on that module.
Thank you and kind regards, Garfield.
ziddabit
Hey,
the production run for the first series has been initiated. Hopefully we will have them ready by end of January 2020.
Once I know a more accurate date, I will let you know.. :)
Thanks, Frank
ziddabit
Hello Frank,
-- GarfieldModular
Hey Garfield,
fyi - we start shipping the Euporie filter from 10. February to a few EU shops (incl. Schneidersladen).
We will also be offering it via our Reverb shop. In the meantime enjoy the audio snippets.. ;)
Cheers, Frank
GarfieldModular
Hey Frank,
Good to hear that the module is soon in the shops, can't wait to test it.
Kind regards, Garfield.
