fosferus
anyone familiar enough with the circuit available to troubleshoot this build? the two gate outputs are reversed, and the length/shift CV inputs seem to be swapped as well. will pay for shipping + time (assuming it's repaired).
Bishop Dust
Hi !
Here is Francois from Shakmat writing - if you have problems with your build, you can contact us at support@shakmatmodular.com. We can also try to resolve the problem here ! Your problem seems quite strange did you check if the biggest chip at the back of the module is correctly inserted ?
