Anyone have problems with the Nano Rand being too tight in their case? I have Tiptop Z-Rails and the module's circuit board just barely fits in the space between the rails. This wouldn't typically be a problem but because the button is so close to the edge it binds up against the rail when i screw it down completely.
(it's also possible that my rail spacing is off -- my cases are homemade so i'm not 100% sure)
Studio-ES
There was a thread on MuffWiggler about this issue recently. It's not uncommon-I had the issue when it was in the bottom row of a Doepfer base-case and had to dissemble the module and trim some of the plastic from the button. I bought another Doepfer case and there's more room. You may want to try to contact Qu-Bit, they appear to be helpful.
