Radian_Pixel
Hi guys
I'm trying to set up my first rack and could need some advice. I own an Arturia MiniBrute which I would like to use as keyboard.
I also own a few FX pedals (MemoryBoy Delay, Freeze, Phaser, Flanger), that's why I don't have any FX in my rack yet.
I'm planning on buying the Doepfer A110LCB which has enough space for a start and can be expanded easily.
I tried to chose parts that have more than one function and/or make sense when adding modules in the future.
Right now it consists of the following elements:
Inetllijel Dixie 2 VCO/LFO
Bastl Instruments Skis Dual Delay / VCA
Doepfer A-124 Wasp Filter
Doepfer A-140 ADSR
Manhattan Analog Three Channel Mixer
With the case included I could stay right under a thousand bucks, but I'm sure I forgot something crucial or did something that makes no sense. :)
Here is my rack:
Looking forward to your thoughts!
Cheers
Radian Pixel
Hey there!
I'm quite new too in the modular world too, but if you want to use your effects pedal you need an attenuator and an amplifier, to reduce the signal from the modular and then to re-amp it from the pedals, there are thousands of different modules and some of them are made especially for using guitars pedals (es. Malekko SND\RTN).
Hope it's clear enough and it will help you!
