KNYST
Updated front panel.
From the site:
Update February 2015: Due to customers suggestions at NAMM (thank you for these ideas) we will modify the module a bit. A manual control will be added to be able to adjust the clock multiplication factor without the need of an external control voltage. The voltage generated by this additional control ("Manual") is normalled to the CV In socket. As long as no plug is inserted into the CV In socket the clock multiplication factor is adjusted by means of the manual control knob and displayed by the LEDs. For dynamic applications (like the ratcheting function described below) the manually generated CV is overwritten by the external CV which has to be fed into the CV In socket.
One LED (the former "0" display) has been removed to obtain sufficient space for the additional control knob. The "0" state is now simply indicated by "all LEDs off".
An internal pin header has been added for additional functions like start/stop (i.e. to start and stop the output clock by means of start/stop signals even if the clock input still generates a clock). If there are sufficient inquiries we may offer a breakout module for these additional features.
KittyDyson
What are the jumper configurations on these? I cant find a full manual for it
Like a jumper config to disable 0 in the pulse rate would be nice, for when manually performing, its hard to position it back to 1 really fast.
Or at least in turn, would've been nicer to have the manual knob be a CV offset instead of being disabled when a cable is plugged in :\
Dyson
KNYST
I suggest you ask Dieter Döpfer himself. A very friendly guy 👍
