Hi, im looking for an envelope generetor, wich is able to be connect to control the accent/dynamic?
I use some parameters, the accent is one of this, which module for accent?
Thanks
solitud
What exactly is accent? Is it the shortening of an envelope on an additional trigger impulse?
EGs with cv-able rise/fall can do this.
i mean a dynamic control of the envelope output level, for example Intellijel Dual ADSR can control it, can i control it also with Intellijel Quadra or make noise math
solitud
Not sure if other EGs have this feature integrated, but since it just seems to be an VCA after the EG output it shut be easy to replicate...
Math can do such things, since it has a sum output for the two AR envelopes.
