Octavian
2 Distings: one to advance a pitch sequence on Peaks' expert mode 4-step sequence as well as to gate a Waldorf Blofeld Desktop synth
Use Blofeld H001 (saved), or A28 in the worst case scenario (same sound)
Variable Parameters: Peaks Knob Values, Blofeld Cutoff, Blofeld Filter Envelope Parameters
Octavian
Octavian
Peaks: set to expert mode 4-step sequence whose pitch is sent to the Dising #2 @ G8 CV-to-MIDI conversion
Octavian
Octavian
Disting Parameters
Disting #1: B5 LFO, using all default settings with 50% Pulse from Output B and 1v/oct (Z Knob) approx. 75%
Disting #2: G8 CV-to-MIDI Converter, all default parameters
Octavian
Octavian
https://1drv.ms/u/s!AsdkBRIREHjWirYxAgb5TiEiy0BfyA
Octavian
