Trying to plan out my first rack.
I'm going to start with just the Neutron and from there add the Plaits or a Braids, and then start adding whatever else I'm itching to add to the case. Planning on sequencing/playing everything with a Keystep.
Agenda item #1 for you: remove the Neutron from this build. If you look at the functions it provides in the space it takes up, you'll notice that it's a bad use of space vs functionality. Try keeping it in its own cab instead. The Roland Aira module can go too, unless you have one, as it's discontinued AND the Eurorack Airas are notorious for huge power inrush draws on power-up, which could spell trouble for your P/S.
Thanks for the heads up on the Aria! I do plan to keep the Neutron out of the case, I mainly just have it included for the visual.
