User left
@galen8
Please make this a private module.
being 3U does not make it Eurorack.
the database is already cluttered as it is. think of the other users here.
thank you
solitud
Mighty admin flagged it as private.
this is eurorack.
i have three mounted in a doepfer 9u case right now.
the module is 84 hp and modular grid only allows modules up to 72 hp.
so i split into two 42 hp modules.
User left
Hi galen8,
eurorack is a specific MODULAR format.
The Oberkorn is a standalone unit, it's not an eurorack module, 84hp or not.
You can integrate it with your modular or not.
There are more examples of other music gear that is 3U high, and it's still not eurorack.
Making the module private is IMHO, the best way to handle this sort of gear. You still get to use your Oberkorn entry on ModularGrid.
Best.
i know what eurorack format is. i have three cases full of it.
this is the oberkorn SLIDERS, not the other oberkorn unit which is a 3 x 16 sequencer.
this one is made to mount in a eurorack case, with a power supply strip that hooks
up to a eurorack busboard. they are sold in cases sometimes which are basicall
84 hp eurorack cases, that mount in a rack. i have two doepfer 6U x 84 cases that mount in a rack,
does that mean they are not eurorack? i would think the more modules in the database the better,
although i will admit not many have these modules. i know as a private module i get to use it myself,
but i'm not arguing to be selfish, just the opposite. i WAS thinking of others when i posted it, thinking there may be others like me
who wanted this. i also wanted an old 39hp blue lantern gate sequencer module but i'm using three of a 13hp as a substitute.
if you still want to make it private, obviously that's fine,
User left
Apologies if I jumped the gun and misunderstood
So you power three OBKs off a Doepfer case?
Eurorack format OBK is not available anywhere and is not mentioned on analog solutions website, nor on schneiders nor on muffwiggler's. I take yours are a one-off custom job or a previous version.
Cheers
User left
Oops sorry, I hit reply before you posted there.
Didn't mean to condescend. Please accept my apologies.
I'm sure the admin can make the module public again, and maybe fix the hp limit too.
Regards.
thanks, i don't mind for myself.
i thought i was helping.
it came with a case and without,
but it is just a large eurorack module. it needs 5v also.
it may be better if the url used for the module is this:
http://www.noisebug.net/site/analoguesolutions/index.cfm?id=76
thanks,
g
solitud
I have extended the HP Limit to 84. So someone can upload this thing again as one module.
  84 hp   is now online  - cheers
