OperatorOne
Hi electro-heads!
Italy calling here. I was thinking about getting the Future Retro Transient module. From what I've heard it sounds powerful and interesting. I love and produce IDM. Love to experiment with noisy sounds. I see there is a new version (called plus) of this module, which has new specific funcions (here: http://www.future-retro.com/products.html#!/Transient-Plus/p/84467820/category=0).
I don't like to have modules that come in a sort of all -in-one solution. I love to modify the sound with patches, so I prefer to go simple regarding single module's functions.
That's why I'd rather go fro the first version.
What do you think?
Cheers.
Glithces and blips can make my day!
I'm not all that convinced that the Transient+ has a point to it. FR touts it as a 'drum module', but it can obviously do more. But the 'more' that it can do is hampered by an underpowered user interface, a storage maximum of a mere 16 gig, and too much going on behind too few controls. So I'm left thinking that it doesn't make sense at all, and it's another example of FutureRetro having the right concept, but the wrong execution.
Consider: if it's a drum module only, then why should it be so big? Most dedicated drum modules are pretty small. So that screws the Transient+ on that front. Seriously...Erica has a pre-sampled drum module with quite a few drum sound options that fits in just 3 hp. You could cram four of those in the Transient+'s space.
But then, if it's a sampler module, then why is the user interface so hampering and why the limited data ceiling on the microSD? That's not exactly what you'd want to see. Plus, in the same general price range you already have other sampler modules that can kick this thing's butt up one wall and down the other.
Or...if it can do all these functions, how exactly do you make sense of this? True, it's got a menu-driven method which makes use of its OLED 'stamp' screen...but consider what a bitch it'd be to jump around between needed parameters in a live performance situation. This sort of UI might work in the studio, but when you're 'under the gun' before an audience...perhaps not so well, then.
Jared Flickinger just hasn't really managed to nail a lot of his company's recent offerings, IMHO. Take the Zillion. Now, here's something with a lot of promise: an algorithmic sequence generator based on the concepts used in the legendary Triadex Muse. Done right, this would be a required buy for a HUGE segment of the electronic music userbase. But it wasn't done right; the user interface wasn't intuitive (unlike the actual Triadex Muse, amazingly) and certain parts of the operation were hampered by a reliance on external MIDI cues...again, unlike the Triadex Muse, which was self-regulating once its parameters had been set. In the end, you got a product that was a niche-type curiosity when compared to what it was initially claiming to be. And ultimately, why would I (or anyone) do this with hardware, anyway? In Ableton Live, there's tons of tools that can do what the Zillion was supposed to...and they fit in the same computer as part of the same DAW being used to create works using both internal software and external hardware. And they're already paid for when you bought the DAW in the first place.
So, frankly, I wouldn't go with any version of this. Look either at more upscale at offerings such as the Orthagonal ER-301 or the 1010 Bitbox+ if you're trying to get at what the Transient+ is supposed to be about...or, as you noted, just assemble the various necessary functions from more basic modules. Either way, you get more to work with.
OperatorOne
HI Lugia and thank you for your response. I have a lot to think about now! ;)
I alreay own the M.I. Grids, which is very useful to create funky and strange rhythmic illusions. I think I'll stick with that and patch it to some nice fx. But then... what would you recomend for some straight and basic drum patterns? Thinking about live situations: I don't really like normal sequencers, I prefer something that triggers as fast as possible the right pattern when it comes to straight up beats, that's why I was thinking about the Transient.
Are there any modules able to save presets and then just play them on the fly?
...hope I made myself clear...
I think, given what's out there right now, your solution is actually going to be in two modules...
Said two modules are in this build: the Erica Drum Sequencer and the 1010 Music Bitbox 2. This setup allows you to change patterns, sequences, etc on the fly with the Erica, and the Bitbox also allows you to trigger things manually by tapping its touchscreen, in addition to its 16 trigger-ins which matches the Erica's 16 trigger-outs.
Also, since the Bitbox can sample, I placed a Ladik stereo input in front of it. Then, since drums like 'punch', I added a WMD MSCL stereo compressor for the Bitbox's output. Handy metering device next, then a Happy Nerding Isolator, which gives you not only a stereo output at line level, but also transformer-isolates the rig's audio outs to help avoid ground loop and noise problems. The Erica Drum Sequencer isn't priced on here, but if you check their website, it's actually 600 EUR. Slap this mess in a suitably-powered 84 hp cab and it's done for about $2k, maybe a bit less. Should be the sort of thing you're looking for...plenty of on-the-fly playability, buttloads of storage for samples, kits, patterns, and sequences, and compact enough to stick in a backpack, more or less.
