We are trying to put together a Eurorack for sequencing and texture to complement our Moog Mother-32 and Arturia Microbrute which are currently sequenced by a Korg SQ1. We're new to Eurorack, and have done a small amount of research into buying a case and powering everything, but we really don't know if this setup will work or not. We'd be looking to fit it into the Doepfer LC3 low cost case, so we think there would be enough power for all of the modules (correct us if wrong).
Any suggestions for getting the most out of this kind of setup would be greatly appreciated!
Thanks in advance :)
Go and have a look at the empty Moog 60 hp cabs and at stacking those in a triple configuration with the Mother32 at the bottom. This gives you 2 x 60 hp to play with for pretty cheap and by adding some small, interconnectible power modules (Koma's Strom series comes immediately to mind) you still wind up with 112 hp for synth modules. Ample power, more space, pretty cheap, and great ergonomics.
See my configuration in the DAMN YOU, ARTURIA! thread under Racks...this uses a triple-tier 60 hp Moog setup in the middle section in which I've specced a DFAM and a full-on performance mixer setup for the larger rig as a whole, which is actually based around major expansion of two of the new Arturia Minibrute 2 synths. You might get a few ideas out of that, especially given that sequencing (via a Minibrute 2S) is a major feature there. But thus far, you're on the right track in general (save that the Braids would have to be a third-party open-source build since Mutable discontinued their version some time back).
