The description here says it "comes with" the TRS jack module, while the Intellijel site says it "connects to" it. I assume the Intellijel site is correct and the expander module is required, but it's not quite clear to me.
worshiptheglitch.com
Dual Balanced Line Audio Input and Balanced Line Audio Output
https://intellijel.com/eurorack-modules/audio-io-1u/The description here says it "comes with" the TRS jack module, while the Intellijel site says it "connects to" it. I assume the Intellijel site is correct and the expander module is required, but it's not quite clear to me.
That's correct, the trs panel is a separate purchase. This is because depending on your case, you may not need it. The 7u case has the trs jacks built in already. The 4u case does not.
I edited the MG entry to reflect the actual Intellijel description.
I’ll check with Danjel. I created the original images and had to add some extra blank space on the top and bottom for them to look right.
