I want to augment a poly synth with more envelopes over midi. My idea is to convert polyphonic midi data to just a series of cv gates (probably with the rk-006). Then I need some AE module to take those gates to trigger a sequence of gates. The sequence separate outs, so that they are polyphonic, will go to maybe 4-8 separate envelopes. These envelopes will be converted to midi cc with the CVMx module and my midi poly synth will have more envelopes than it did before.
I've looked at the sequencer modules for AE modular and the I've looked at the IMDI poly conversion chain. While the IMDI would probably work, I don't need the other data (pitch, bend, etc) and would be less modules if the sequencer method could work. But I'm not quite seeing the best sequencer module for the job. What module am I looking for?
geusensdriesmusic
Converting everything (twice) is overcomplicating things imo. Just get a blokas midihub, process midi coming from your synth and send it back out as cc's. You can f.i. generate random values on every incoming midi note. Just keep in mind: midi will never be as smooth as cv. If you really wonna go with a module, check ORN8 (O_c Teensy4.1 running Phazerville). Full midi support.
ambient • electronica • microtonality
diy eurorack & pedal builder • bassist
My music on Bandcamp: https://driesgeusens.bandcamp.com/
