the-erc
About a year ago I asked for advice on shrinking my setup in order to move continents. I got some nice suggestions, and here is the rack I made. ModularGrid Rack.
The video is a demo of what it does, actually using very little of it. Will post more over time.
Description of patch follows for those that are interested.
The main drums (kick, snare, hats) are from the PO-12 drum-machine, which comes into the rack via Bubblesound Booster Stage and gets multed to the main mix (SSF Vortices) and the FX send (2hp Mix). Bastle Thyme+ is the getting some of the drums (only) to make the dark synthy tones in the background, and later on with different settings the flangy sounds. This also comes back in via Booster Stage.
The metallic sounds are made by Noise Engineering BIA going through the Doepfer A-121-3 high pass. It gets trigger from the Arturia Beatstep Pro, and two AD envelopes from Pique as modulation (also triggered by BSP) attenuated by the Ph Modular 3xATT. All the other sounds are the Bastl Crust, which is gettng pitch and gate from BSP.
Pam is sending clock to BSP, Thyme, and PO-12. Vortices has some self-feedback patched in to fatten the sound.
And that's it. Several modules doing nothing (Disting, the switches, Skis) and Pam being dramatically under-exploited. Just goes to show you don't need a lot of gear to achieve a lot. Also using only about a third of the sequencer tracks that BSP can provide.
